Adds or deletes an ExtremeXOS module to or from the Web server target.
target | Specifies an alpha numeric string that identifies the configured target. |
module | Specifies the name of the ExtremeXOS module. |
N/A.
Use the add option to attach a module to the Web server target in order to receive events from that application and send them to the targeted Web server. There is no limitation to the number of modules that can be attached.
Only Identity Management and EMS are supported targets.
Use the delete option to detach ExtremeXOS modules from the Web server target in order to stop receiving events from that module.
The following command deleted the target test2 from EMS:
configure xml-notification target test2 ems
This command was first available in ExtremeXOS 12.4.
